It is currently Thu Aug 21, 2025 1:44 pm
PostPosted: Thu Aug 29, 2013 11:22 am
First name: Rusty
I'm planning to build a small vacuum frame for a bridge glue-up. The 3/8" closed cell gasket I'm using is going to be cut from a sheet of what I was told is neoprene rubber for a seamless gasket.
The soundboard will have a nitro lacquer finish on it.
My question is there a problem with nitro and neoprene reaction? I've heard the stories about vinyl so I don't want to take a chance.
I know there's folks out there that use vacuum and would really rather do that than go the C clamp route.
Btw, I will be using hide glue and plan to clamp about an hour.
Sent from my iPhone using Tapatalk 2
PostPosted: Thu Aug 29, 2013 2:41 pm
First name: Rodger
Last Name: Knox
City: Baltimore
Zip/Postal Code: 21234
I think you need to do a test on scrap, that's the best way to be sure. I think neopreme is OK with lacquer, but there's several flavors of each of these materials, so your best route is to test what you have.
PostPosted: Thu Aug 29, 2013 3:02 pm
First name: Stuart
Last Name: Gort
Neoprene is the typical sponge rubber used on guitar stands so it's a fairly safe assumption you're ok. I can't imagine there would be a reaction without a solvent present. ...testing wouldn't hurt anything.
StuMusic
PostPosted: Thu Aug 29, 2013 3:08 pm
Since you will only have one hour of contact you should have no problems. The problem occurs when lacquer is in contact with the vinyl for days or weeks at a time.
PostPosted: Thu Aug 29, 2013 3:29 pm
First name: Rodger
Last Name: Knox
City: Baltimore
With a new build and fresh lacquer, there will still be a small amount of solvent outgassing, and the contact time for reaction to occur will be at a minimum. I agree you're probably OK with an hour or two, but the risk of having to sand and refinish the top would induce me to do the test. bliss
PostPosted: Thu Aug 29, 2013 3:45 pm
Last Name: Fifield
City: San Jose
Zip/Postal Code: 95124
Make sure the lacquer is fully cured and rock hard before you vacuum-press glue the bridge on, otherwise the force of the vacuum will mark the finish where the seal touches it.
DAMHIKT....
Dave F.
Cambrian Guitars
PostPosted: Thu Aug 29, 2013 4:12 pm
First name: Rusty
Hey guys,
Thanks much and I agree a test sample is a good idea. Dave - thanks, I hadn't thought of that.
One more thing i overlooked is the membrane I got from Joewoodworker is polyurethane if I'm remembering right. I'll have to see how that will react with nitro, it looks a lot like vinyl. Hope it's ok, i sure do like vacuum.
Users browsing this forum: Bing [Bot], DennisK and 14 guests
